For the past few weeks I’ve been researching crossovers and everything related. But I’m finding that as I go, the more advanced it gets and I’m now at the point where I need some help because I'm not understanding.
I’ve tried every calculator that I’ve found through Google and I cannot replicate the values in the original crossover network. Not even close. Then again, not knowing the current inductor values doesn’t really help me either. To me, I can’t justify dropping $100+ on high quality capacitors without knowing that as much of the frequency as possible is being played by one or more speakers. Why does that worry me? Because with the current values right now, there seem to be a few frequencies that I can’t hear at all through my CW S-1’s but I can hear perfectly through my TV’s speakers. it really bugs me. Not to mention that the previous owner put two different 12" woofers in it so the sound is pretty off.
So what I would like to do is recalculate the crossover network and replace every component including the inductors to make 100% sure that every possible frequency is covered. I know that impedance varies while the speaker is in use but when calculating the new crossover values, should I use the ohm values written on the back of the speaker, or the values that I get when read with a DMM? The reason I ask is because the tweeter reads 4 ohms on the back of the speaker, but when read with a DMM, it reads 2.2 ohms. Unfortunately I haven’t been able to locate any data specs or frequency response curves for the mid or tweeter and yes I already contacted Cerwin Vega directly. The only spec sheets I have are for the 12” woofer because I’m replacing them with a new pair.
I have plenty of other questions but I’ll hold off on those for now because my questions may change depending on the answers I get, assuming I get any. I thank you guys in advance. So far I’ve had nothing but great help and it’s greatly appreciated.
EDIT: Added original crossover schematic for reference if needed. Much better than my other attempts I think.
