I just completed a build of a little Single Ended EL84 guitar amp. I tried to follow a schematic from a Fender Tweed Princeton amp as best I could, but this was a 'left-over' parts project and I really had to rather 'make due' in some cases. The Princeton schematic uses a 6V6 and is at a much higher voltage than my PT could produce. I have a schematic for a similar amp that Antique Electronic Supply sells as a 'kit'...there MOD102 kit. I also incorporated parts of it into this build as well; particularly the output section and PS supply. I did use a choke......a Hammond unit, a 156 I believe......1.5H, 200ma, 50 ohms.
Anyway....... the amp is about 98% there! It's up and working, has 'acceptable' numbers in most places. I've got about 230V on my EL84 plate, about 190V on the screen, and about 125V on the two 12AX7 plates. I'm running a 150 ohm cathode resistor, bypassed with a 100uf/100V cap, and showing about 5V across that resistor which I believe calculates to about a 32ma current draw on the tube...which is a 'new' JJ 6BQ5.
I say I'm at about 98% because I have one remaining issue, which is that the amp will 'motorboat' from about 3/4 volume level on up. If kept below this level, it sounds and plays fine. But, hit about 2/3 to 3/4 on the VC and it breaks into this oscillation........audible even with the guitar vc turned all the way down. So, just looking for some suggestions as to what to do about this? Any help would be appreciated.
Many thanks!! Tom D.
