benindavis
Hi gang,
So my VietNam vet neighbor gave me his 8080DB that had been hanging around in his garage for a few years collecting dust. Good for me, right? So I opened it up and blew out the dust ( remarkably little by the way) plugged it in and everything fired up. Some crackling on the volume and balance but otherwise all systems go. I figured Id leave it alone til I could get some DeOxit and some of the new WD 40 Contact Cleaner. Got the WD and gave a few things a spray, waited a bit and powered up. much improved! I was pleased, and walked away from it and decided to do a serious clean on a day when I had time to do it right. A few days later I gleefully powered it up and ... Speaker protection mode. ok.. did some research and replaced the R33 and R34 180 Ohm resistors. Plugged it in powered up ! sweet!!! decided to do the bias and DC offset. Did the bias adjustment no prob. Then..... I began to try the offset. ... I accidently touched something I shouldnt have while attemtping to measure off of the fuse holder and a tiny spark and a pop on my speaker occured . oops....now. the speaker protection is on again andthe dc offset is WAY high, and it wont adjust....
Any ideas on where I should start to look or what I have done to this fantastic gift I was given???
Thanks in advance
Ben
Thanks in advance
Ben
