Pre out. 1020
I just picked up a NAD 1020 preamp for $20 (yippie!). It's 22 years old, same as me, and works great! I have a question, the preamp has two sets of preouts, one labeled 'high level preout', and one labeled 'pre-out'. I use the high level pre out since I feel it sounds richer and warmer than when I hook up my adcom amp to the regular preouts. I was wondering what are the technical differences between these two preouts? Also, would I be able to biamp using these two preouts, or is there a way to split the signal from one preout to send to two different amps?
In fact I have the same question. I got 2 integrated amps NAD , the c326bee and c375bee.
Now the first preamps the second.
Before when I did not have the 375 yet, the 1020 preamped the 326.
Now, that 1020 produced much higher volumes with the tiniest turns of the volume.
Now, this is no longer so. The volume is more spread at the turn of the volume and volume produced is lower.
So I thought , in order to keep the 1020 in use to use him as preamp for both.
But you need 4 speakers then, I guess, which I have. Each amp will get a preout feom the 1020, but do need speakers no ?
Thanks.
And using a rca switch to split the normal preout !?
I suppose however the high level out can do no harm, on the contrary.
The aim is still to combine both amps. In a 4 speaket scenario this should work no.
As I have a speakerswitch I can cut 2 speakers off, but without loosing power for the orher 2.
Appreciate advise.
