bradfro
I've got an NAD 2100 power amp, when turned on, the protection light remains lit, and the speaker relays never click on. After checking all the AC input voltages, I checked the DC power supply outputs and they all seem fine. The problem is there is 26v on the test point to measure idle current. This is on the left channel. The right channel works perfectly. I was able to adjust the idle current for the right channel to around 15mv
I’ve attached a schematic
If I follow back the 26v(red circle on the right side of the left channel) I come to a point where there is 0v indicated by the capacitor circled on the left. This seems to me to be the origin of the problem, but I can’t find anything wrong.
The point where I’ve indicated 6.4 and 7.5v on the right channel (good channel) measures nearly zero, maybe something like .6v.
I’ve replaced C401, I’ve pulled and checked D401, d403, Q453 and q454 with an ohm meter and they test good. Q401 and Q403 are part of an op amp, I think. Anyway, I’ve swapped these with the right channel and the problem remains on the left side. R401, R403, R405 seem to measure good in circuit.
Can anyone point me in the right direction on this, I’m stuck
Thanks
Thanks
