I would say that helps plenty! Thanks!
Voicing is highly dependent on the characteristics of the output transformers used. You will likely need to adjust the feedback amount as well as the feedback capacitor. You will also likely need a step filter (sometimes called a shelf filter). Step filters perform the same function as a Zobel (limits HF extension as to avoid instability) but it's done on the small signal amplification stage rather than on the high current output of the transformer secondary, so smaller wattage parts can be used.
I have never used the 1650HA, so I can't really comment on them. I have used the 1650H in several builds, and it's very good to excellent in the LF region (below 100 Hz) and produces a fine sounding amplifier. But the 1650H is only "so-so" in the HF region (above 10KHz). Some focused tuning is needed to limit HF extension to not create an oscillator in to arbitrary speaker loads when global feedback is applied. This is the one big weakness of the 1650H and by extrapolation to all of Hammond's line of 16xx push-pull line of transformers that do not have the "A" suffix. Specifically, I've used the 1608, the 1650H, and the 1650R, and they all exhibit this same issue in the HF region.
I assume the same desirable LF characteristics exist for the 1650HA as the 1650H. But I really don't have experience with these so I can't comment further. Here's what I can say: I have no desire to use the 1650H (or any other Hammond non A suffixed transformers) in any new builds I might do. I would be willing to try the the "A" suffixed transformers if I were in the mode of building another amp and I didn't have any other better options. My hunch is the 1650HA is a better overall performer than the 1650H, but that's only a hunch.
Hope that helps.
