need some help with a reel to reel
puckett59
Member
hello all,i got a old reel to reel(penncrest 6433) from my brother&i could use some help.first thing i need help with is how do i get the play,fast forward,rewind knob off?i tried pulling up on it,prying gently up on it,didn't move any!don't want to pry to hard cause of plastic.i was able to see under the faceplate that the belt was broken.thats my second question,where can i get a belt for this?thanks in advance for any help.
Look for an opening along the bottom rim of the knob at the vertical piece(Look under the arrow). There may be a screw inside underneath that you need to loosen.
According to what i found @ turntableneedles.com, Belts for the 6433 are REWIND BELT #RBL 11.2 ($14.95) and the counter belt RBS14.0 ($11.95).
Larry
