Plimpington2
He should absolutely do that. He can isolate the noise that way.Might pull out the main - preamp connectors and see if that has any effect.
Haven’t tried tape monitor yet but all other inputs
Some update on my project. I pulled the jumper out between the preamp and output board and still had the popping noise so I shorted the input to the output board and the noise was gone!
I am trying to figure out the replacement transistors but having a hard time on some of them. If anyone has any suggestions I would greatly appreciate it. I do have new output transistors and some possible replacement for the npn, pnp pair but the other 3 are questionable.
I guess I should list the ones that I have trouble with.
2sc281 (b)
2sc627 (3)
2sc871 (r) f
Thanks, Jim
Thanks I will check it outThere's a guy on Ebay, Peacelovemusic, or something like that. Sells rebuilt kits for the Sansui driver amps. Good reviews here on AK for his kits. Might look into this and just do a complete rebuld? A 5000X is well worth the time and money.
In reality they are a complementary pair which is interpreted differently than what you might expect. They are complements since one is PNP and the other is NPN but they are not expected to have the exact same hFE performance, just very similar behavior overall.... mje15033g ... and a mje15032g ... a matched pair.
The hFE difference is pretty typical between NPN and PNP devices even complementary devices. The hFE of 10 that you see on DigiKey is the minimum value for a fairly atypical operation condition (Ic = 2A, VCE=5V) that is reported in the datasheet. The hFE that your tester measured is done under closer to typical conditions and it's not unexpected that it will be higher than the minimum you see reported by DigiKey. In this part of the circuit there is a fair bit of latitude about how similar those transistors need to perform and you can be confident that the new ones will work just fine to drive the output transistors. You won't need a curve tracer unless you're after the absolute best performance matching and are willing to buy and test more than a handful of parts.On DigiKey they were listed as having a gain of 10 each but when I got them the gain was very different...
Thank you very much, I sure have learned a lot from people like you and I appreciate it.In reality they are a complementary pair which is interpreted differently than what you might expect. They are complements since one is PNP and the other is NPN but they are not expected to have the exact same hFE performance, just very similar behavior overall.
Maybe more of an issue will be physical differences between the TO-220 and TO-66 packages. Judging from the pcb layout, you might have to solve some component clearance concerns with the squared collector tab of the TO-220 parts.
