CheeseofBorg
User Serviceable Parts
For the past few months I have been trying to fix a speed issue on my Sony TC-666D. After installing a 3d printed 60hz capstan, it still ran a little slow. I did some searching and found this : http://audiokarma.org/forums/index.php?threads/sony-tc-660-r2r-speed-problem.98443/
Where Fred suggested replacing the phasing capacitor. I did so by replacing Capacitor 504 on the schematic (which has been uploaded to HifiEngine by a helpful member) with two 1uf capacitors (rated for 450V) in parallel to match the 2uf capacitor. When I fired the unit up, not only was it still running slow, but the new capacitors reached over 300 degrees Fahrenheit after about a minute at which point I shut it off. I turned it on briefly to check the voltage across the capacitors and it read at 97V if that helps. What should I be looking at as my next step of troubleshooting?
