New product intros!!!!!
McGuy
Just got this today!!!
Product Announcements for the exciting new MR88 AM/FM/HD/XM Tuner and the MX150 Preamp/Processor.
The MR88, which is scheduled to begin shipping at the end of this month, will have MSRP of $4,000!!!!
Next Item:
The MX150 won't begin shipping until May but the announcement is being sent now to enable dealers to plan for future installs.
The MSRP of the MX150, shown on the announcement at $12,000!!!!
And guess where you can hear the MR88 in may ?
Now begins the thousand posts debating the looks of the 88 and whether the 150 is worth the price. Let the stampede begin. :lurk:
April issue of TAS reports that MX150 features jointly developed with RoomPerfect room correction software which requires up to 10 hours to record and plot 25 separate measurements. Curves are customizable on a PC via Ethernet port. A CF card slot allows the settings and entire configuration to be saved on the card. :smoke:
The new MX150 12-channel, 2-zone Audio Video Preamplifier from McIntosh is designed to command the most
advanced home theater installations with a potent suite of features including multiple subwoofer and center channel
configurations, an electronic crossover function and on-board RoomPerfectTM processing. System settings are saved and
software updates performed via USB and Compact Flash. A built in Web Interface allows remote control, set up and
service of the MX150 from any connected browser. The latest audio processing insures seamless compatibility with
BluRay disc players. Incoming digital audio signals are re-clocked to minimize jitter for the best possible audio
performance. The MX150 is ready to decode both Dolby TrueHD and DTS-HD Master Audio formats in addition to
Dolby Pro Logic II, Dolby Pro Logic IIx, Dolby Digital 5.1, Dolby Digital EX, Dolby Digital Plus, DTS 5.1, DTS ES,
Discrete 6.1, DTS ES Matrix 6.1, DTS Neo 6, and DTS 96/24.
Five HDMI, five Component, two S-Video and two Composite video inputs guarantee room to grow and are assignable
per source. Video signals are minimally processed in order to preserve their integrity and maximize hardware
compatibility. Analog video is transcoded to digital HDMI with the original scan type, line resolution and frame rate
preserved. HDMI video is passed through unaltered.
The MX150 boasts 12 channels of audio output. The four extra channels may be configured in a number of exciting ways.
An active crossover feature allows biamping of front loudspeakers, while multiple subwoofer and multiple center channel
options expand the performance potential far beyond typical surround sound installations. No mere exercise in channel
stacking, these output scenarios are fully integrated by the on board RoomPerfectTM processing: Crossover, EQ, Delay,
Level and Phase are all optimized in the process.
The audio processor and room correction work in concert to automatically set loudspeaker level, delay, bass management,
crossover and room equalization. This process is exceedingly accurate. For instance, loudspeaker distances are set to
within a fraction of an inch tolerance. The image steering and three-dimensionality resulting from this process simply
must be heard to be believed.
Two pairs of balanced inputs combine with balanced outputs and a differential balanced audio topology to deliver superb
low level linearity. Single-ended connections include a moving magnet phono stage and a multi-channel input as well as
eight assignable stereo inputs. Coaxial, optical and AES/EBU balanced digital audio inputs are provided. An on-screen
user interface is menu-driven and intuitive for ease of system set up. An RS232 input offers compatibility with third party
remote systems while McIntosh Power Control and Data Ports enable the MX150 to operate your entire McIntosh system
from a single hand-held remote.
With features and functionality far beyond those of typical A/V preamplifiers, the MX150 sets a new standard for high
performance home theater.
MX150
A/V Preamplifier
Audio Inputs
1 AES/EBU S/P-DIF input
4 S/P-DIF coaxial inputs
4 S/P-DIF optical inputs
2 Balanced stereo analog inputs (XLR)
8 Single ended stereo analog inputs (RCA)
1 Multichannel single ended analog input (RCA)
(for 5.1, 6.1 or 7.1 input)
Audio Outputs
12 Channels:
• 10 Balanced (7.1 + 2 balanced expansion
channels)
• 2 single ended expansion channels
• 8 single ended outputs (7.1)
1 single ended Zone B stereo output
1 Microphone input (XLR) for RoomPerfectTM calibration
Video Inputs
2 Composite
2 S-Video
5 Component
5 HDMI (v1.3)
Video Outputs
2 Composite
2 S-Video
2 Component (1 RCA, 1 BNC)
1 HDMI (v1.3)
Software Update and Control
1 DB9 RS232 connector
1 3.5mm jack RS232 connector
2 IR sensor inputs
8 McIntosh device IR (Data) outputs
2 McIntosh device summary IR (Data) outputs
2 McIntosh keypad connectors
2 Trigger inputs on rear panel
6 Trigger outputs
1 USB-A (software updates)
1 RJ45 Ethernet connector
1 Compact Flash slot (Storage for system software and settings)
Great audio tuners are defined in part by their excellent ability to receive a wide range of signals.
Recent developments in digital broadcast technology bring a broad array of listening choices
before the consumer and force us to reexamine the standards by which audio tuners are judged.
Enter the remarkable new MR88 AM/FM/HD/XM Audio Tuner from McIntosh. The McIntosh
MR88 excels at receiving traditional AM and FM broadcasts and adds the power of HDRadio to
produce startling fidelity with an expanded range of programming. The capability to control a
subscription based, outboard XM Passport Module accesses the power of satellite radio to
complete a palette of unprecedented choice for the consumer.
The MR88 features single-ended and balanced audio outputs for superb fidelity, while coaxial
and optical digital audio outputs offer surprising flexibility. A 2 x 20 Vacuum Fluorescent
Display reads Artist, Title, Genre, Station, and Signal Strength and may be set to time-out in
between tunings. Twenty station-presets per band
guarantee instant access to your favorite
programming.
By way of updating of the dial-cord and fly-wheel
tuning method found in classic McIntosh tuners, the
MR88 employs a smooth-acting, weighted tuning
mechanism with an animated dial pointer for an old-school analog feel with the precision and
addressability of modern, digital systems. An inverted chrome chassis lends a note of opulence to
the MR88 that further recalls the collectible McIntosh tuners.
The MR88 ships with a full function IR remote control, and supports McIntosh Data and Power
Control as well as third party controllers via IR and RS232. The unit measures 17.5” (44.45 cm) x
6” (15.24 cm) x 17” (43.18 cm) (W x H x D) and weighs 25.5 lbs (11.57 kg) net. The MSRP of
the new McIntosh MR88 is $4,000 (U.S. and Canada) and initial shipments are scheduled to
begin in March.
Still waiting for info that we don't already know...
"How solid is that May ship date?" would be my first question.
Remember, we had XR200 press release a long time ago, and I can only think of... one... dealer with a pair. Nobody has demo's, even the Premier's.
Something to do with the paint? Whatever the excuse, I tend to not hold my breath for proper availability until at least a local Premier dealer has it en-route (at the very least).
Couple of points.
Max size of a PDF is 1 meg
Sounds to me like your talking about something tens of times this. Even if we allowed files of this size your 2.5 meg capacity as a registered user would not. If you were a subscriber with the larger 70 meg upload capacity one or two of these files would eat your entire capacity up in no time.
:beatnik:
+1:beer: So I will believe it when I see it. Until then I'll drink a little stout and listen to the music but these product announcements are getting boring.
