This may be a stupid question, and I apologize if this has been beat to death by others, so I apologize in advance if this is a rehash of the past, but I'm looking for just a little common sense and wisdom from you veteran repair folks in regards to this issue. When looking for suitable replacement Nichicon caps for Audio gear, like in the pre or power amplifier sections of the Pioneer units, there obviously are a lot of "options" in the series of caps when it comes to selecting what is needed. I'm trying to decide if paying more for a cap that is designed for audio equipment is worth the extra cost, or if a general purpose cap is adequate and sufficient to be used as replacements in amplifier sections.
It seems that the UPW series is the most commonly cited replacement, which according to Nichicon is a "General Purpose" cap. But then there is:
UKA - High Grade, For Audio Equipment
UKZ - Premium Grade, For Audio Equipment
UFG - High Grade, For Audio Equipment
UKT - General Audio Equipment
UKW - Standard, For Audio Equipment
UFW - Standard, For Audio Equipment
USW - For Audio Equipment
UMW - General Audio Equipment
Obviously, the Premium and High Grade caps cost more, as well as some of those other ones listed. Is it worth the cost to replace with these higher grade caps? Is it just about sound quality, can the average listener tell any difference in sound between a premium cap like the UKZ or the general purpose UPW, which is much less expensive. Any thoughts would be appreciated.... Thanks.
