Norman Labs Surround Repair
bob1033
Hey guys, I recently moved into a new house and they left behind some Norman Laboratories model 52 speakers they bought in the early 90's. They left them behind because the surround had dry rotted. I almost have a complete system, so I want to repair these. How should I do this?? They have 6.5" woofers that need new surround, and i wanted to know if any had any experience with Norman labs speakers, not many people do.
I have no experience with Norman labs but I'll look them up. The trick with any re-foam job is using the right surround. Many foam kits are generic - one size fits all woofers of a given size. You may end up significantly changing the woofers T/S numbers, and not for the better.
Ok, thanks, i just want the best fit possible, I attached some pics.
Norman Laboratories is now, unfortunately defunct. Their speakers are desirable however. Your model 52s are of a sealed design. I'm in a similar situation with a pair of AR TSW310s which have rotted surrounds. The surrounds needed to minimize change to this type of woofer's characteristics are the thinner ones used on such woofers - AR, Advent, KLH, etc.
There are several companies that sell surround kits; Speakerworks, Midwest Speaker, My Audio Addiction, etc. But again, the key is getting the right one - not a one size fits all generic.
As far as the actual process of getting the old ones off and putting the new ones on; A lot has been written about it, what solvents to use and not use - acetone, alcohol, brake fluid - and what glues to use, and not use. There are many threads on Ak about replacing foams surrounds.
Ok, i'll look at some surround kits, but im not sure which on ewould be the best. im kinda a speaker noob, any suggestions on which kit to buy?
I have used Speakerworks kits about a dozen times now and have never been disappointed, YMMV.
Nice speakers, welcome to AK.
Wow, that looks like the exact same surround, and the picture of the finished product looks just like the cone of the norman, the spec match up, so this is the one i think.
Thank you guys so much!
I have a set of 52's as well, and literally the first time I played them (bought a couple years ago) the foams self-destructed. Mine are still in need of foam as well - I bought MAT Electronics surrounds, but haven't fitted them yet.
Yours is the first pair of 52's I've seen besides mine.
Haha, I thought I was the last one on Earth who had a pair of 52's, let me know how they fit, im ordering some surrounds in a few days.
Also, another question, will using rubber surrounds change the acoustics of the speakers, they had originally had foam surrounds.
Yes. There are all kinds of complicated things going on with surrounds. Before I knew much about driver design, I wondered why supposedly competent designers of quality speakers like JBL and AR would use cheapo foam surrounds when they knew that they would in time rot. Well nothing lasts forever - entropy - even rubber surrounds will dry out and fail - it just takes longer. Rubber has different damping qualities, which (among other things) will affect the upper range of the woofer - the midrange. Those designers weren't being cheap. They knew what they were doing.
So happy that these old forum posts are long lasting...I just picked up a pair of Norman Lab Model 52's as well and in need of new surrounds. mynameisphun and bob1033, you both appeared to use different replacement surrounds and I was curious how each worked out. I plan to order replacement surrounds today and your feedback is much appreciated.
