Hello, my first post on this forum!
I have recently acquired a Nottingham Analogue Spacedeck with what I think is a SpaceArm. I purchased it secondhand and don't have much information about it. I think it is an early model - as the platter only has one damping ring. Here is a picture of the deck.
Worth saying that I am really pleased with it. It replaces a Rega RP1, which I had for a number of years, so quite an upgrade. I was told it had a new motor and belt, and I also got the protractor and some bearing oil. The foam mat I think is correct and I do believe I read somewhere that the original dust covers were just plain black acrylic as I have here. I acquired it for £800, but sold the cartridge which came with it, so in effect it cost £700 for the deck and arm, which I think has got me a lovely deck and arm.
The arm wiring had no labels on the tags, so I had to meter those out and I could also see some kinks in the wires going into the arm. In addition I could see that the wires seemed to be incorrectly routed between the arm and base - appearing to have to wrap around the the metal rod joining the arm and base from front to back rather than just dropping straight down behind. I also noticed a crackle or popping sound (like static I suppose) through the speaker when touching or moving the arm. My suspicion therefore is that the arm I have has at some point been rewired, and perhaps not very well.
So yesterday I decided to have a go at rewiring the arm internally with cable rescued from some apple earbuds - a tip I read on here. It's working fine, but I continue to experience the crackle when touching the arm. Inside the arm was the cotton wool like material at the head of the arm. I was expecting to find another couple of pieces of the 'cotton wool' further down to keep the wires away from the arm tube, but instead found (an reinstalled) a piece of copper? (at least full conductive) mat, around 120mm x 40mm x 3mm deep, wrapped around the cables at the pivot end of the arm tube. I wasn't expecting this, but did reinstall it. I now wonder if this might be causing the crackle? Shouldn't the cables be held away from the walls of the arm internally by something non-conductive? Does anyone know what should be inside the arm?
There seems to be remarkably little information about the Nottingham Decks out there. But I have read several posts by @Fishead here, and would be very grateful for any more information that could be shared to help me along with the turntable. Being in the UK, I'm sure I could send the arm to NA to be serviced and rewired, but keen to see if I can sort it myself. I'm quite happy with soldering and fiddly work - also a bit of a model maker and I studied Electronic Engineering at university a long time ago...
Here are some photos of the rewiring as it is at present.
Thanks for reading this far and in advance for any advice.
James
James
