babyrigger
Hey there, everyone.
So, I have a general cry for assistance. I don't know much about the physics of radio
, but I listen to a LOT of FM and just moved into a new house that has an old aerial on the roof with a cable that I could potentially run down into my tuner in the livingroom. Would there be any problem with hooking this up just to see how it affects the signal? If its not designed to be an FM tuner, I know that I might not expect some sort of "audiophile" quality, but it seems reasonable enough to think that a big hunk of metal would have to be an improvement over the little wire antenna that I have.. Is that based on some kind of fallacious understanding of hoq FM signal works, or should I go for it?
Thanks for any advice...
Chris
, but I listen to a LOT of FM and just moved into a new house that has an old aerial on the roof with a cable that I could potentially run down into my tuner in the livingroom. Would there be any problem with hooking this up just to see how it affects the signal? If its not designed to be an FM tuner, I know that I might not expect some sort of "audiophile" quality, but it seems reasonable enough to think that a big hunk of metal would have to be an improvement over the little wire antenna that I have.. Is that based on some kind of fallacious understanding of hoq FM signal works, or should I go for it?Thanks for any advice...
Chris
I'll obviously adapt this to whatever I find up there (still haven't been up to check it out), but do let me know if you think I'm headed towards folly with that basic blueprint in mind.
