johnnm
Audio Enthusiast
I have a Tektronix 475A. It's in working condition (bought it calibrated). When there's no signal being applied to either input, there is no trace. I'm certain that earlier I had a flat line trace when no signal is applied, but now the trace just disappears. For example, when the source is an amp's speaker outputs, you get the wiggly lines you expect, except every second or so, for a very brief moment, the trace disappears. ("Signal" light signifiying a signal is being applied also turns off.)
Any idea on a setting I might have changed or anything else to look for in order to get the scope to display a straight trace line when no signal is being applied? It's irritating.
