Steelman
Very handy tool to check some components, like audio caps, besides using the VTM, put a square wave or sine wave through a cap and see if it is distorted or not. Have fun with it and play around with it to get the hands on experence you need, but stay away from the high voltage stuff for now.
Note: Discharge the larger electrolic caps used in power supplies, before doing any tests.
Read up on you manuals and get to know the scope very well and really understand the grounding method and safety precautions you need to use to test amplifiers and receivers that have to be tested with the power on.
I thought using a scope was to be able to "see" the input signal (sine or square wave) from input to output, and observe for distortion. Then trace back to the non working board or devise.
Can this be done with the unit off?
