slimecity
Hi -
I'm thinking of getting a Syscomp Circuit gear mini for testing and diagnosing a Technics SU-V10 integrated (and learning how to use a scope as I go....). It integrates with your computer and will run with my Mac. This seems like the best cost/benefit option for me.
Most scopes seem to have a DC limit on what they can test - this one has an upper limit of 40VDC. The voltages in the circuit I will test are up to 60VDC. The manual says: “Warning Our recommended maximum input voltage on the AC coupling setting is 40 volts DC. Exceeding this may cause damage to the electronic switch that selects between AC and DC coupling. You cannot use the AC setting to block DC voltages larger than this value……If you need AC coupling where the DC component of the signal is larger than 40 volts, you should put the coupling in the DC position and connect an external capacitor of the appropriate voltage rating in series with the input.”
Any help on how to do this, and what cap value to use for this application would be appreciated!
Cheers
Cheers
