paadigm 3se reglue surround
klausp
I have a pair of paradigm 3se
they have rubber surrounds
on one of the speakers the glue was comming undone on the surround and the poly cone.
I carefully removed all of the glue.
what glue should I use to reglue the rubber surround? there doesnt appear to be anything wrong with the surround
as well, i need 2 dust caps, do you just get any kind, or is there a special paradigm dust cap?
As for the dust caps paradigm used the porous see through type where the pole piece was visible, but since they are ported I suppose a solid generic cap would work if you can't fond those. Not sure on the glue for rubber onto plastic....contact cement??
I had paradigms that had the surround problem more than once, both while under warranty
I had the same problem and just used good old white glue and it has bonded just fine. Don't forget to shim the voice coil.
