gloveofpower
First posting: I'm looking for some technical/troubleshooting assistance. Maybe this is the right place, maybe I am posting in the wrong area? Please forgive me if so!
So I picked up a Panasonic RA-6600 (it's got a built in 8 track recorder!) that has some issues and I would like to get her operational. I have limited/some experience troubleshooting audio equipment but I am skilled with a soldering iron, already familiar with microelectronic component types/functions, and handy at repairing things in general. I am a younger guy and hoping to find a forum where I can learn about repairing vintage audio equipment because it could become a wonderful lifelong hobby for me if I were to get good at it. And the only way to learn is by doing! Perhaps you seasoned veterans could help get a rookie started?
As for the Panasonic, the guy who I bought it from said that it was working great (and he seemed genuine) except for the fact that it had blown fuses on the back. He said he thought that someone had bridged the speaker outputs while disconnecting it and therefore replacing the fuses should restore it to operational status. I replaced the fuses with appropriate 2 amp fuses and hooked up a small speaker to test her. When plugged in and turned on, the single lamp which lights the front display did not turn on (filament inside the bulb appears intact). The speaker buzzed and I could see the cone withdraw to its maximum inward position. Searching around online, I found an article saying that behavior of the speaker cone which I observed is a very likely sign of a shorted output transistor from the power amp section, trying to output the full rail voltage into the speaker terminals.
I located what I assume to be the amplifier transistors, mounted onto a big aluminum plate to serve as heatsink. I couldn't directly see the transistors because they are housed inside a protective box (the black box in the image below) but I'm pretty sure these are the ones. I took my multimeter and set it to the "beep" continuity-test setting and touched a probe to each of the leads in various combinations to search for shorts. Interestingly, I noticed that certain locations would produce a momentary beep which then went away in about 1 second. Is this a capacitive effect, or what am I observing there?
At this point I'm looking for possible culprits to investigate which might cause this failure. Or, more broadly speaking, helpful websites or articles that can help teach me how to diagnose problems. When I bought the Panasonic, the guy said here, I've also got this broken Sansui 210 (a pipsqueak) which doesn't power on. You can have it for free if you're into fixing things he said. So that's next after the Panasonic. Thanks in advance for helpful comments or resources!
