Phoenix Record Cleaning Fluid
jazzwolf
Has anyone tried Phoenix Record Cleaning Fluid from Sleevetown.com? I was wondering how it compared to some of the other fluids available for a record cleaning machine.
I had thought about trying it out but haven't yet. Buy some then report back to us. I just got 3 refills of D4 after being out for so long. I had no luck whatsoever locating any locally in the whole Phoenix metro area and so I finally ordered some from the NeedleDoctor.
Pheonix Record Cleaning Fluid
I'm also interested in feedback re Pheonix since it is less than half the price of DD, VPI, Last etc. The 8 oz bottle is around $10 and I might give it a try. I'v been useing VPI fluid for my VPI 16.5 RCM.
Pheonix RCM Fluid
Go over to the asylum where you will find a number of posts re Phoenix. All in all sounds like it does an acceptable job of cleaning records from what they said.
I guess I'll give it a try, the gallon is about 25.00 which is less than 1/2 the price of some of the other cleaning liquids. I've been burnt before but who knows? I might discover a gem instead of coal :D
Old thread-but for those who are interested. I have used this system for a number of years, and it works great. The kit with the special microfiber cloth is a great starter, add a quart for $16.95, and another one or 2 cloths, and you will be set for a while if you hand clean. It incorporates enzymes, along with alcohol (to dry quicker).
I start with the Mofil brush, and end with the microfiber cloth. Soak the cloths when in Woolite, and air dry.
Apparently it works well with a machine also, but haven't gotten a machine yet.
They also make a alcohol free formula for 78's
I use it as a 1st step with dirty used records, and I spread it, let it sit for a few mins, then vacuum, since it has enzymes... let it sit and work on the grunge. Works fine. I follow with Mofi and then distilled water rinse.
I use it by the gallon. Works great. Can be a little "sudsy" if applied too liberal, but a good rinsing takes care of it. I use it as a mid-step before AIVS. spyderx is right, it has enzymes so I let it sit as long as possible before vac'ing. You can also opt for the alcohol free solution.
+1. Good stuff.
Ive been using it for some time now. It gets the job done I suppose at a premium price.
Does anyone know the exact ingriedents for this solution? Is it worth the extra coin rather than the standard homebrew: Distilled/IPA/Dawn solution?
Since there is no ingriedents listed, im thinking I am paying a premium for water and alcohol in a nice black bottle with a cool phoenix rising logo.
