Pioneer CT-W603RS belts
2fives
Pioneer dual deck circa 1994 CT-W603RS
Anyone know where to get 'em?? I looked on wjoe's site but didn't see any.
I'm having FF issues where the deck stalls out then just goes into stop mode.
There's a possibility that they may still be available from Pioneer in Long Beach.
If you use generic parts, as are widely available through various internet sources, make sure that the flat belt is thin. It should be .020" or, at the worst, .023". Many internet belt vendors do not have a clue that a belt thicker than that will usually cause a significant deterioration in the wow-and-flutter figure (short-term speed stability). The wow-and-flutter introduced by a .025" belt can often be heard.
Here's another rule: a belt should stretch about 5% between fully extended but not under tension and stretched onto the pulley(s). For example, if a belt in a "relaxed" state is 10.0" in circumference, expect it to stretch to 10.5" when it's on the motor pulley. Looser than that and it may slip. Tighter than that and it will load down the motor, cause speed problems, and kill the motor and flywheel bearings.
Fred
