I've had the good fortune to purchase one of these tables locally. I have been cleaning it and recapping it. I have replaced all the electrolytics on the power supply board and the control board. These are no problem to remove and service. Now I want to recap the board for the drive motor. I've replaced some of the capacitors that are on the perimeter with success, but have not replaced some that are more interior in location as they are tougher to reach when trying to install replacements.
It would be much easier to replace them if I removed the motor from its mounts on the base but I am worried I will disturb the alignment/geometry between the spindle axis and the arm. I have the service manual and it does not address removal or replacement of the motor assembly and any alignment issues that could arise. Does anyone have experience with this model or know if the mounting of the motor is designed to locate it precisely without adjustment?
Another challenge I am facing is the suspension. Mine came missing the springs (PBH-169) at all four corners and the "case assemblies" (PXB-185). Does any one have any springs or case assemblies? I have placed a WTB add in Barter town Parts. Does anyone know of viable substitutes for the springs? If you have the case assembly part and don't want to sell it I could get by with dimensions to make my own it someone wouldn't mind measuring them. I could even provide a "looks like" drawing where the dimensions could just be filled in. Any help or advice will be appreciated.
and I ordered "Professor Bizzt's" spring locating rings that will complete the suspension.
