Sounds like a bad ground on the balance control. A cap somewhere may be providing a ground until it charges up.I've done this test 4 Times Now, turn it off turn it back on and balance works, Leave it on for a few hours and balance stops working. This is in the speakers and the headphones and regardless of anything I click or change or turn on the SPEC 1 Balance does not work.
Not sure, it takes anywhere from 1 - 3 hours for it to start doing that.Sounds like a bad ground on the balance control. A cap somewhere may be providing a ground until it charges up.
No the spec 2 works fine as far as I know, I just got that back from Service. When I Turn individual knobs on the spec 2, turn top knob, the right channel goes quiet, bottom knob is the left channel goes quiet.Do you mean the volume controls on the front of the Spec2 don't work? The Spec2 is an amp and has no balance control. That would be in the preamp.
You have a bad ground on the balance control. Measure the resistance between the power supply ground and the chassis and from the chassis to the balance control. If there are shielded cables on the control, the shield is ground. You probably have a broken wire somewhere.So let me explain clearly if I can. I turned the stereo on this morning The balance on spec 1 the preamp works perfectly I turn the knob to the left The left channel plays I turn the knob to the right Only the right channel plays all is good. About halfway through a CD I turned the balance knob on the spec one preamp to the left and nothing happens, It continues to play on both speakers, I turn it to the right and nothing happens it continues to play on both speakers.
Thank you, I'm working two jobs and I have kids so I will get to this one of these days.You have a bad ground on the balance control. Measure the resistance between the power supply ground and the chassis and from the chassis to the balance control. If there are shielded cables on the control, the shield is ground. You probably have a broken wire somewhere.
And a list of some of the components that I've changed in the SPEC 1. Has to give you some history Not sure of anything there would affect the balanceYou have a bad ground on the balance control. Measure the resistance between the power supply ground and the chassis and from the chassis to the balance control. If there are shielded cables on the control, the shield is ground. You probably have a broken wire somewhere.
SPEC 1 bottom.Check the grounds on that board. You probably broke a wire when you were working on it.
That picture is not high enough resolution to see anything if you zoom in.SPEC 1 bottom.
On first inspection of the bottom, I don't see loose wires, anything disconnected, or any touching.
Ok, and FYI Here's the with no power on the spec one it's not even plugged in, Waveform generator hooked to the Aux 1 and scope record out, And this is good and I let it run for a while and the purple line goes away. I shake the entire spec one and it comes back So yeah something is loose somewhere. I tap on everything and move everything around and it doesn't change anything so it's internal somewhere I'll have to dig into it more.That picture is not high enough resolution to see anything if you zoom in.
Measure the resistance between power supply ground and the chassis. If that is good (less than 1 Ohm) start measuring from the chassis to ground on the balance pot, and every place on the filter board that is supposed to be ground.
I gave you the troubleshooting method, to measure the resistance of the grounds. You didn't do it. Maybe you'll get lucky but since you didn't do any testing you won't know for sure.OK so I deoxed everything again and shook the heck out of it several times. I tighten all the screws I could see, and for 4 hours the scope has been solid. I picked the thing up and shake the heck out of it and it holds solid. So I'm gonna let it run for another day and see if it holds solid on the scope and then try it out. I just don't wanna take it all apart if I shook loose whatever the issue was? I just learned from experience messing with things that don't need messing with can cause more problems. We will see.
Oh I know and I'm keeping all that in mind but I really don't wanna have to take the entire thing all apart and pull the boards off to do all that if I don't have to I hope you understand.I gave you the troubleshooting method, to measure the resistance of the grounds. You didn't do it. Maybe you'll get lucky but since you didn't do any testing you won't know for sure.
