I recently acquired a RT 701. It appears to be a clean and well cared for machine. It plays back pre recorded tapes great. I try to make a recording and one channel is weaker on the VU meter and it plays back very fuzzy and distorted.
Are there any known issues and suggestions for an easy fix? The heads have very little apparent wear. I did need to clean the monitor switch before it would play or record. The tape path is clean.
I tried two different input sources and swapped channels on the playback. The distorted channel stays on the left channel.
I will need to open the recorder, the tape counter doesn't work, I have a new belt and capstan on order. I can clean switches and pots at that time.
I don't really know much about tape recorders but I have built and repaired a lot of tube amplifiers.
