hairybiker
I have a SA-940 in which it differs from the service manual.
The output transistors are 2sc3546 and 2sa1389 pairs.
Also, the values of idle current preset and resistor result in a minimum idle current of 160ma ( 36mv at test points ) with preset fully anti clockwise.
All solder joints are original and the only parts that may have been disturbed are the output transistors.
Now, the service manual for boards fitted with the 2sc2525 and 2sa1075 pair says that the idle current should be set to between 36 and 100ma ( 8 to 21mv on TP ).
The idle preset and its paralleled resistor are different values to the ones mentioned in the SM.
Does anyone know of an addendum to the service manual?
Thanks
Mark
Thanks
Mark
