mbottz
I have searched this forum for weeks and found all the information to repair my Spec 2. For the repair I replaced the driver transistors Q4,5,6,7,12,13 with closely matched ON-Semi MJE15032G and MJE15033G Transistors as directed by Echowars. Also Replaced the Bias relays with new units as directed in another thread. Replaced the 2SA798 Differential pair transistors as well for DC-offset. Adjusted the bias voltage to 30mv after a 45 minute warm up. Adjusted the current limiting sensitivity with VR2 & VR3 per the manual. All checks out on the scope. Bias is very stable. DC-offset is 6mv and 9mv.
The unit plays beautifully, But......... the meters deflect at power on to between .1W and 1W as soon as the protection light goes out. There also seems to be a bit of decoupling noise on the right channel at power off as well.
What am I missing?????? :scratch2:
Is there somthing else in the protection circuitry that needs work?? Any help with this would be greatly appreciated.
Thanks
Mike
Thanks
Mike
