Ignore all readings provided as I discovered + Fluke probe had an intermittent short. Since my post on the weekend I found a short on STV-4H and replaced it as well as a disconnected primary wire to one of the outputs which has also been repaired. DBT test now working fine with no smoke but no protection click either. Have retaken all readings with new probes for reference:
Output board readings:
Pin 1 -48.5v
pin 2 -48.5
pin 3 0
pin 4 & 5 34.9
pin 6 0
pin 7 & 8 48.5
pins 9-13 0
pins 14 & 15 -41.2
pins 16 & 17 -48.4
pin 18 0
pins 19 & 20 34.9
pin 21 0
pins 22 & 23 48.4
pin 24 0
pins 25 & 26 -4.2
pin 27 -2.3
pin 28 -4.2
pins 29 & 30 40.7
pin 31 -40.9
pin 32 -4.3
pin 33 -4.8
pin 34 -4.3
pin 35 -4.8
pin 36 40.8
pin 37 -2.3
pin 38 -3.2
pin 39 -2.3
pin 40 -3.2
pin 41 -40.6
pin 43 0
pin 44 -.6
pin 45 -.6
pin 46 40.6
pin 47 .1
pin 48 .6
pin 49 0
pin 50 .6
Pin 1 -48.5v
pin 2 -48.5
pin 3 0
pin 4 & 5 34.9
pin 6 0
pin 7 & 8 48.5
pins 9-13 0
pins 14 & 15 -41.2
pins 16 & 17 -48.4
pin 18 0
pins 19 & 20 34.9
pin 21 0
pins 22 & 23 48.4
pin 24 0
pins 25 & 26 -4.2
pin 27 -2.3
pin 28 -4.2
pins 29 & 30 40.7
pin 31 -40.9
pin 32 -4.3
pin 33 -4.8
pin 34 -4.3
pin 35 -4.8
pin 36 40.8
pin 37 -2.3
pin 38 -3.2
pin 39 -2.3
pin 40 -3.2
pin 41 -40.6
pin 43 0
pin 44 -.6
pin 45 -.6
pin 46 40.6
pin 47 .1
pin 48 .6
pin 49 0
pin 50 .6
