Polygraph K (ultimate version?)
Fabio75
Good morning to all. I hope you can help me. I came across this component, which according to the seller should be a POLYGRAPH in polygraphite, a latest version. What do you think? Is it actually an updated (original?) component or is it one of the many fakes that are found, like for the Polydomes? Thank you
That's the RSDS polygraph. It uses the same frame as the polygraph found in the Kappa 8/9, but was designed for automotive use. The dome is actually IMG. Pretty rare, actually.
It will probably work as a drop-in replacement for the polygraph in the Kappas, but those rarely fail, except for accidental damage. What's your use case for it?
