gogofast
Addicted Member
been using ampex 402 (i think this is the model) preamp for last few years with no problem. all caps changed out silicon diodes put in. all of a sudden both channel's output is about 1/10 of what it used to be. sound quality is there though.... changed tubes and still same output level. according to the schematic, 280v and 210v should be going into the 12ax7's and one 12au7. but when i tried to measure, somehow readings are all funny..... other than line in, 120v AC, none of the DC readings make sense to me. heater voltage of the 12ax7 is about 7v....due to high line voltage and silicon diode i guess.... will need to adjust the resistors, but right now, i'm puzzled about the low volume.
does it sound like a resistor or two being out of spec? what other reasons could there be? thanks for any help. i can post schematic when i get home.
