Hi
I'm having an issue with my right channel in my 2120. I probed around with my scope and am not sure what to make of some of the traces and would appreciate any comments. Below are the speaker outputs for the left channel and right channels for a 1 kHz square wave.
Left Channel
Right channel
I have the Power Guard switched to off/out at the back of the unit. I'm not sure if the issue is somewhere with the LDR or the Power Guard opamp. If I compare the scope trace between pin 7 (Power Guard Input) on the molex connector between the left and right channels, I see the following:
Left channel
Right channel
Also different is the output of the power guard opamp (pin 6). Below are the left and right channels of pin 6 of the opamp. Input Pins 2 and 3 of the PG opamp look like normal square waves for both left and right channels.
Left channel
Right channel
Below is the schematic of the right channel power output board
Left Channel
Right channel
Left channel
Right channel
Left channel
Right channel
