Trawlerman
Well-Known Member
Folks,
I've got some questions on the differences of headshells. I know that headshells are important to sound quality of from turntables and definitely make a difference but i'm unsure of why that should be so?
A fixed headshell on a one piece tonearm (e.g. RB300) will be better because of the overall continuity of the arm. I've got that OK.
But why when one has a quality tonearm with a detachable headshell should there be any major differences. I realise that the headshells can be manufactured from a wide range of materials such as Steel, Magnesium, Aluminium (or other alloys), Carbon Fibre, Plastic. The material that it is made from will obviously make a difference to the overall weight of the headshell but as long as the counterbalance is of a sufficient weight this shouldn't make a difference or should it?
I suppose that the other question that follows on from these points are what are considered to be the best headshells around?
I've seen vintage Orsonsics that are quite well regarded, also seen Empire Carbon Fibre ones and a Yamamoto HS-1/1a Ebony Wood. Any thoughts on these?
