question about my M97xe and the tracking force guide
bbb777
hi all,
quick question. when using the sure tracking force guide to measure the correct tracking force on my cartridge, should I be measuring it with the stabilizer brush down? I want the cartridge to run with the brush down so i figured i should measure with tracking force with it down right?
G'day mate, yes this can be a little confusing actually. The Shure recommendation with the 'brush' down (how I use it) is 1.75 g. With the 'brush' up, adjust your counterweight for 1.75 g tracking weight at the tip. I don't trust 'counterweight calibrations', I use a tracking weight scale.
Anyway, with the 'brush' ('aka dynamic stabiliser') then down, it 'absorbs' half a gram tracking weight, so effectively the tracking weight at the tip is 1.25 g. If not using the 'brush', readjust the tracking weight to 1.25 g. I hope that makes sense! Regards, Felix aka catman.
