Brent3Cats
Anyone with the newer version of this with the Phono stage built in?
With nothing hooked up to the phono input - no rcas or ground wire - there is what sounds like a 60hz hum that gets louder with the volume knob. Not loud, just there but definitely noticeable between tracks.
The Bluetooth and auxiliary inputs have no audible background hum / noise at loud volume.
When hooking up a turntable and grounding it to the amplifier there is no additional and no less hum/noise than with nothing hooked up and the input switched to phono.
Anyone with this amp - do your units do this? Is this an issue with mine or just the amplified noise floor from the high preamp gain required for phono carts in general?
Thank you very much if anyone sees this and can answer my questions.
