howardtheduc
First, is the normal way speakers are hooked up "parallel"..ie matching terminals on the amp one to one to those on on the speakers? If so, does an amp then see a load of 4 ohms when you hook up 2 8ohm speakers in that way and should it's output be calculated on the 4 ohm column rather than the 8 ohm? Are our amps running way hotter than we know when we think we are being kind w/ 8 ohm speakers? Would we be kinder if we hooked up 2 4 ohm speakers in series? Also, if we series connect 2 8 ohms in series do amp love or hate a 16 ohm load..does it sound good? My curiousity is peaked on this stuff but I fear experimenting! Thanks in advance!
