MAIN SYSTEM:
POWER ON;
1. Switch on reciever, push the button for whatever component I wanna use, turn the volume up a bit
2. Switch on EQ
3. If it's CD or Cassette, I switch the component, insert a tape or CD and push play. if it's 8 track or LP, I either just push in the 8 track and select programme, or put the LP on the platter and set the tonearm on the record.
4. Adjust volume. if the bass and treble needs adjusting, I adjust those, and sometimes the EQ if it needs it.
POWER OFF;
1. Take CD/LP/Cassette/8 track and put it back (It bugs me when there's a record left on the platter, tape in the deck, etc)
2. Switch the component off, or close the dust cover
3. Switch the EQ off
4. Turn the volume all the way down and switch off the reciever.
SECONDARY SYSTEM:
POWER ON;
1. Switch the unit on
2. Turn the volume up a little bit
3. Switch it to either 8 track, Phono, AM or FM
4. Insert an 8 track, put on an LP, or tune the radio
5. Adjust the volume, and if I'm playing a 78, I turn the treble all the way down to cut back on hiss.
POWER OFF;
1. Take the LP or 8 track and put it back
2. Turn volume all the way down
3. Switch the unit off.
I've really gotten into the habit of always turning the volume all the way down before I shut the stereo off, and that goes back to my first real stereo; my old Lloyd's all in one, which would sound like a lightning strike if you had the volume up when you turned it on and off.
