Purchased a really nice set of 10B crossovers. Nice to have a clean undamaged pair. The originals I refurbished that are in my 10B now were damaged. The originals were rebuild with C1; Sonic Cap Gen 1’s, C2&3; Axon Truecaps, and Mills 2.7 Ohm 12-watt resistors. I like the sound of this setup but there is a problem my Yamaha is occasionally acting on in the left side 10B.
I know a whole lot more about the subject, plus I have much better equipment to do the job with.
I am looking at using a complete set of Mundorf MCap EVO 450VDC cap's and a set (4) 2.7 Ohm Vishay Mills MRA-5 resistors. Apparently, the MCap EVO is not made in a 250 VDC version. It isn't the voltage it is the physical size of the caps, smaller would be better. I used 12-watt resistors on the original set, I seem to recall that was all I could find at the time. The schematic calls for 5-watt resistors and that is what I am going use. Looking at the datasheet for Vishay Mills MRA-5 resistor it can handle up to 25-watts for brief periods that is good enough. The Polyfuse will be replaced by a 0.5 Ohm 5 watt Vishay Mills.
I know, I can spend fantastically more money but this parts list comes in at bit over $100 bucks at Sonic Craft. Any suggestions?
