rob29
Alright, well I am fairly new to the audio scene as I only started this hobby within the past year. I just graduated from an electronics technician course this past week and am off within the month to join the Navy as an electronics tech (cant wait!!). I am very comfortable working around electronics so I decided to try out some things with my first reciever, which is currently being replaced by a Marantz sr100 which I got for $30(Sounds beautiful).
The reciever that I am currently working on is an AKAI AA-1020 that I picked up for free and I thought sounded amazing until I started listening to the little things. I was getting what sounded like AC distortion in the speakers when the volume was turned up with no signal so I figured it was the capacitors in the rectifier/ power amp stages. I just completed recapping them, double checked everything, and turned it on to test.
Well... the noise is still there. I poked and proded a little bit more and found that when i touched some capacitors the noise slightly went away. I also tested the DC offset and got a extremely bad 600mV from both channels :thumbsdn:.
So this has led me to think that there may be a bad ground somewhere and decided it clip from chassis to grounding prong on a power bar and the noise dropped quite dramatically. So next I am going to put a new power cord with a grounding prong on it just to be safe. But there is still some noise and I really want this amp back in order.
Any help would be greatly appreciated for a yound guy who is looking to waste some time.
