Recapping a Sherwood S2000 Tube Tuner - Question
Some not so good news now.
Well, once I moved it to the main system, it no longer sounds very good and is not picking up many stations. I think I definitely need an alignment (no big surprise after a re-cap job). I may also have some bad/weak tubes - I don't have a tube tester to check them with. I think I'll probably re-tube to match the re-cap, then get an alignment.
Just ordered complete tube set
Ordered from AES - total cost for 13 tubes = $60. I like the fact that the NOS tubes for this tuner are still inexpensive!
Anyway, now to wait for the tubes. I suspect that I will still need an alignment after re-tubing; is there a recommended tech in the Central NJ area that AK members are happy with?
