lb: Well, the switched outlets on your unit appear to be blocked, anyway, so these wouldn't have to be aditionally considered. Then I'd go by the main fuse (1209), which for 230 V use should be 3.15 A. Typically there are no 750 W units, but only 500 or 1000 W, so I'd get a 1000 W step-up unit - but before I'd of course check the possibility of internal rewiring. Problem is that the schematic of the PM7000/8000 is rather confusing in that regard, covering too many versions at once for me to properly get it...
Anyway, are you going to connect a turntable with regular MM or MI cartridge? Then you should mod the phono input and throw out the excessive input capacity in form of the two 470 pF caps (2253 & 2254) and the two 680 pF caps (2255 & 2256) and replace the latter two with a more sensible value like the 150 pF that are originally installed in the F and U variants. If you've got a cart that wants to "see" a very low load capacity, you could go even lower, but you'd better not go much below 100 pF, so the input doesn't receive Radio Moscow or whatever, if there's no turntable connected...
Oh, and there's a little bug in the block diagram, showing the "record selector" (the PM7000/8000/7200 aren't true record-selector designs) in position "off", but if you look at the position of the switches in the diagram, these are on position "source". And if you look at the implementation around the "record selector", it becomes clear that for whatever reason Marantz chose to ground the output to the delivering tape in both tape copy positions instead of leaving it connected to the selected source, so on these amps it's not possible to pipe a source signal through a processor on one tape loop and record the processed signal onto a recorder connected to the other tape loop via the tape copy functions of that pseudo "record selector". Just so you know, in case you'd ever want to try that.
Greetings from Munich!
Manfred / lini
