.....I'd like to know what best Teac deck that has these characteristics.
The Teac A-6300 is a great older deck from the seventies. The X-1000R, X2000R are newer decks but still highly regarded. I've owned both. The A-6300, I think, is more solid(tank type build). The later decks have more bells and whistles.
I have a Teac A3440, which I will likely keep.
I'd like a deck that has the following characteristics:
1. speeds of 3.75 and 7.5 IPS as a minimum;
2. autoreverse;
3. 10.5" reel capacity.
Thanks!
jv
Id say a 6300, but you say you have a 3440, what is the problem with that unit, the fact that it doesn't play 3 3/4? Otherwise Id suggest a 3440, lol.
Yes, like most things, it's perfect, but...Id say a 6300, but you say you have a 3440, what is the problem with that unit, the fact that it doesn't play 3 3/4? Otherwise Id suggest a 3440, lol.
Maybe that's it!I think he also is just looking for another pretty face.![]()
The A-6300 would be my choice if I absolutely had to have auto-reverse. If you can do without auto-reverse then I'd recommend the simple, reliable and rock solid A-3300SX (1/4 track stereo version). That will do the lower 3.75 speed and is a fantastic performer for a home use machine.
The A-3300SR does have autoreverse. You can sometimes pick these 3300 units for less than $50. And they'll probably outlast us!
