"So it was a highly regarded speaker in the late 60's and early 70's."
From December 1967 HIFI/Stereo Review, Equipment Test Report, Hirsch-Houck Laboratories
"Our side by side comparison with a full-range electrostatic speaker (Quad), which we consider to be one of the finest reproducers available, proved to our satisfaction that the two could not be told apart, except in low bass, where the Rectilinear III was clearly superior."
"The Rectilinear III can be driven by any amplifier capable of 20 watts output, which includes practically all integrated receivers, yet can handle the output of the largest amplifiers."
"At $279 the Rectilinear III is not inexpensive...Nevertheless, in our opinion, we have never heard better sound reproduction in our home, from any speaker of any size or price."
From Rectilinear Research Corp., Instructions for the use of the Rectilinear III Floor Standing Loudspeaker System (no date, but came with purchase):
Required Amplifier Power
The Rectilinear III is a medium efficiency speaker system requiring substantial amplifier power for a high sound level. It is therefore strongly suggested that an amplifier of at least 20 watts RMS of power per channel be used with the Rectilinear III. The use of 50 to 100 watt RMS amplifiers for large rooms and high sound levels is not unreasonable."
From Rectilinear III Floor Standing technical sheet, 1970, Rectilinear Research
Crossover frequencies: 500 Hz, 3000 Hz, 11,000 Hz
Nominal impedance: 8 ohms
Minimum power requirement: 20 watts rms
Maximum Power Handling capacity: 100 watts rms
Frequency Response: 20 to 18,500 Hz +/- 4 dB
