Hi all, I could use some help. I have an amp here (RealisticSAF40B) that has a moderate redplate in one of the four output tubes (push pull 7189s). It doesn't follow the tube; it happens in the same location, regardless of which of the two tubes in that channel I use.
What I've done:
I swapped out the electrolytics and paper/wax caps, all resistors checked and on spec. The usual cleaning pots etc., all tubes test good though not super strong. I haven't noted voltages on tubes yet but will after I write this. One thing I have not done yet is change out the selenium rectifier that rectifies 40 volts from the transformer and looks like it splits it off to power the heaters on the two preamp tubes and also the bias supply.
This is a fixed bias amp as there are no cathode elecrtolytics/resistors dropping straight from the cathodes/grids to ground. Instead they go into a resistance network and elsewhere in the set.
Unfortunately I do not have a good schematic, so I'm kind of winging it It's pretty fuzzy and low res. See pic below.
Anyway, there are no bias pots anywhere on this amp, so it's got to be set fixed bias. Assuming I've got the bias too hot, how then do I cool it off? (in general terms for now) hopefully more in depth as I get voltages and some guidance on how the bias setup in this amp works.
If you all could help me deal with this and maybe cool the bias off a bit, that would be fantastic. I would rather run it cool and conservatively and save the 7189s than push it too hard and cause potentially major issues.
Edit: Here's the best shot of the schematic I have. It's not great but better than nothing! Thanks. http://imgur.com/a/OYa23
Thank you!
What I've done:
Thank you!
