2.5 feet is more than enough to deflect a main board to the point of cracking so I'd be looking for solder traces with dmm, Check any pcb ground screws, wire connectors etc.
I see nothing wrong with the two 'okays' and it is a photo. So why don't you 'experts' post a pic of your 'ideal' good joint(s) by hand and not solder bath flowed.
It is very possible to have at least something "reasonable" and one must when doing a lot of joints, as just one being open can be enough to blow up an amp.....
I replaced an ic on a almost 30 years old circuit card from an old system at work, today. (yes there is such stuff around, still operational)
(This is done having ONE GOOD EYE ONLY due to rectina surgery a month ago, still leaving some macula problem at one eye giving distorted sight. First soldering thing since 3 months..)
As the pins were bent on solder side I had to cut every pin on the ic, and take it out one by one.
The finished-pic of the IC itself shows the flow is not 100% through to the top side of the card, but everything makes contact and it works.
I just did a two seconds flow using the soldering iron because the tracks are sensitive for loosening from the old card. Tracks for power 3 seconds, maybe.
The finished picture is before cleaning off the residu after soldering.
I am not getting paranoid when it looks a little "lesser" but once soldering you easily get the feel if flow is good enough or not.
Now this is a one time attempt but people soldering every day will very soon have the feel of how long exactly it takes to have the joints all look the same.
Good to know. I've never found a need for more than the flux in the core of my solder. Could be that's because I use the good solder or mainly work with new work as opposed to reworking old stuff.
Yes old stuff can be a real PITA.
