I have a Nikko Na-100 integrated stereo receiver with one or more bad op amps, i just replaced both Output OP amps with 4556's which from what i understand has a higher output current to push high impedance loads such as headphones. Is there any negative effects of using it in my application? The receiver works well now and sounds decent, unless im able to A-B between the two i cant say i hear a difference. Is there any particular reason why i shouldn't have used the 4556 and used something else instead? Im also open to Desoldering and putting something else in there for better sound quality if it would make a difference.
