Dearslayer
I have a 2230 that was part of a package deal from a friend of mine but the shaft on the function switch was broken but he also had a replacement that he was gonna eventually have a tech replace for him but never did get around to it. He gave me the switch with the unit. I'm between projects at the moment so after much researching here on AK and having a stomach full of butterflies I decided to make the leap and attempt the swap. I had read about a few different suggestions such as inserting a swab stick as a follower behind the screw while removing it and it worked great on the bench with lots of room but in my case there was no room to get it in behind the switch. I decided to try a different approach so I mixed a little 5 min epoxy and using a tooth pick I managed to get just a small little dap on both ends of every spacer where it contacts the waffer just enough to just hold it in place so the spacers wouldn't fall out. I did this on both sides and let it cure for an hour. I will admit I was sweating a little when I slowly backed out the screws. Much to my surprise it all stayed intact for removal and insertion of the new replacement shaft. I hope this might help someone else who might be a little hesitant to give it a go.
