Revox A77 power supply replacement
Spoosy
Member
I just bought a nice looking Revox A77, but the guy didn't have the origin 2-prong power chord. I understand it shouldn't be a problem replacing the outlet with a standard 3-prong outlet so I can use one of the many of those chords I have laying around. The procedure shouldn't be hard, but what I'm having difficulty with is figuring out how to get to the outlet on the RTR deck. What screws need to be loosened to remove the panel to give me easy access, so I can rip that sucker out and solder in a standard 3-prong outlet?
Thanks a bunch!
Also - I can't seem to get the NAB adapters off. It seems like it should be an easy task, but they just won't screw off....
The matching 2-pin power cord is readily available. It's an IEC C9/C10 cord/socket combination, widely used on European gear at the time (Revox, Tandberg, etc.) as well as on some pro gear like Roland.
If you can't spot one online (eBay and most music supply places will have them for very low prices), drop me a PM and I will point you to some sources.
John
Well, since I don't live in the States, shipping is very expensive. I don't want to put down $50 for a $5 cable.... So I'm still bent on trying to replace it with a 3-prong. But I'm still not sure how to remove the top plate.. any ideas?
Thanks!
Thanks!
Four screws on the back of the cabinet - then the whole deck can slide out.
Hi Spoosy, you don't need to do surgery on your A77, these cables show up on a regular basis on the Bay. Incidentally they're the same for A77, B77 and PR99 Mk I. There is no problem whatsoever really: Revox parts are plentiful, especially in Europe.
The NAB adapters are just held in place on the turnables like any tape reel, by pressure applied by the central shaft. Just pull it, rotate it by 60 degrees so that the three prongs are aligned with the slits of the adapter, and let lit go. It will let the adapter free, and all you have to do now is pull it off.
If you need the manual for you Revox, you will find them all on the Studer FTP site: ftp://ftp.studer.ch/Public/Products/Revox/
The only problem is that since I don't live in the US or Europe, shipping costs get really ridiculous.
Just to check if it works - (and this is probably a really, really stupid question) could I take a normal power chord, use paper clips or whatever else to hook the male side of the Revox to the female side of the chord, and plug it in to the wall? Or is this just the stupidest thing to think?
It really is a dangerous thing to do, prone to causing shorts. Here's what I do when the wood cabinet is off (not implying that it's safe, just much safer than what you wanted to do):
- Remove the wood cabinet. You just need to remove the 4 screws and the dummy plug - put the latter back when the cover is off, or the keyboard won't work.
- You will see a little plate holding holds two 4mm banana plugs inside the wood cabinet. This is a safety feature: these plugs make contact in the black small plastic box next to and over the power socket , so that the recorder cannot be operated unless it's in the cabinet. See the two 4 mm holes? These are the matching 4 mm sockets, and the plugs makes the circuit within each ot them (not between them!) so the mains makes it to the power supply.
- You can use these holes as an alternative power socket, by inserting ordinary banana plugs into these hole. One plug is connected to live and the other to neutral. Do not short these two plugs!!! Needless to say, you do this at your own risks, electrical safety is not guaranteed - especially if the bananas get snatched from the holes.
I'd still look for those 2-prong IEC cables though, but that's just me. BTW the wikipedia says that the same C9-C10 socket was used by Roland for some of its equipment, e.g. the TR-909. It might be worth giving it a shot. The modern 3-prong IEC socket should fit the same size as the original 2-prong socket, but the replacement is more challenging than it appears at first sight: you have to destroy the 5 rivets (that's the easy part) and then replace them with something that does not protrude either, otherwise you won't be able to slide the cabinet back in (there is hardly any clearance). Ordinary screws with cylindrical heads won't do!
So I've decided against doing it myself as I don't think I have the expertise for it. I went to a guy who deals with these items and he was very much against doing it - he said if I really can't get my hands on a cable he will, but he'd rather not ruin such a nice machine (they're very very rare around here)
Shipping here is ridiculously expensive, but I will be in Sweden in about 10 days, and I'm guessing it will be much cheaper to ship it there. Any recommendations are welcome! (I'm guessing via PM?)
Thanks!
Good move :thmbsp: My recommendation is simple: start by searching "Revox cable" on the 'bay, and you'll find quite a lot of them. I wouldn't trust the sellers who say "Revox Teac, etc.": many of these sockets had similar looks but different dimensions that made them incompatible. Revox and possibly Roland are the only names that should appear in the description. I see that several sellers in Europe have the right cable and have "buy it now" options, so you shouldn't have problems. Shipping to Sweden is not a problem either.
Roland did use the same C9/C10 solution, and I'm convinced that's largely the reason these cables are still readily available.
Cables specified for Tandberg, Revox, or Roland or that specify the IEC C9/C10 spec should be ok. It's the Japanese brands like Accuphase, Teac, etc. that have the similar solution that is not interchangeable with the IEC cables.
John
Thanks!
Here you go...
http://www.ebay.co.uk/itm/Revox-Pow...ageAudio_RL&hash=item4d0e3ae4bd#ht_985wt_1170
I bought one a few weeks ago - perfect.
