Rotel RA-812
002
Hi all,
I have a Rotel RA-812 that I am trying to fix up. It works and plays fine but has a very annoying issue whereby activating the three separate 'Filter' toggles for Subsonic, Low and High on the front of the unit causes a loud popping sound through the speakers. I've attached a schematic excerpt below.
Notes so far:
  • I have nothing connected other than a single pair of speakers.
  • Volume control does not have any effect on how loud the pops are, but I have it set to minimum.
  • All three toggles cause a loud pop - they are slightly different but all *loud*.
  • Subsonic is unique in that if I set the Low filter to 'In', toggling the Subsonic filter on or off does not cause any pop. As soon as I toggle the Low filter off again, Subsonic will pop again when toggled on or off. High and Low always pop regardless.
  • Switching the speakers to off with the control on the front hides the noise, but I still see the VU meters jump up like they would do if the speakers were on.
Any insights in to what might be causing this?
TIA.
I just realised I forgot to state the issue in my thread title. If a mod could kindly change it to 'Rotel RA-812 - Speaker popping issue' or something to that effect, that would be appreciated.
Both VU meters deflect, so issue with both channels.
Reads a bit like some dc voltage bleeding through coupling caps C509, 510, 511, 512, 529, 530.
With Hi Filter in, does switching the low cause a pop?
Thanks both. @mbz it was exactly those caps (C529, 530) you mentioned.
Most of the electrolytics in the unit are grey Elnas which still measure OK but I was suspicious of the lime green Sanyos because most of the 1uF's I was measuring were reading around 6uF. I did not think to check C529 / 530 because they were a good distance away from the filter controls and I supposed they were for tone control. I replaced the other coupling caps for good measure.
Problem solved!
Problem solved!
Most capacitor testers don't check for leakage, which is most likely what the issue here was.
  • Like
Reactions: 002
