Infidel
I've inherited a SA-300, and can't find a manual for it. I can find a SA-100 manual, but it's not anywhere near the same.
The RCA jacks on it are marked IN Filter OUT. I've been listening it using a laptop with RCA plugs going into the IN and am leaving the OUT alone.
The preamp was built in a tiny bud-box. It's all point to point wiring. I can't use it at this point because the RCA inputs are too close together for modern cables. - and I don't understand it. It has two pairs of RCA jacks coming out. I think both were used. It appears to have a rectifier tube, a 6CG7, and what appear to be 2 12AX7's. I've tried to wiggle them free but suspect they may be soldered in place.
I would start building something like a 6SN7 preamp for it, but really don't know what I'm getting into if the inputs include a high / low filter.
So far, bass isn't too tight - or just different that what I'm used to hearing. That, and using a MacBook for a source isn't ideal.
