I pulled out my problem child SA-9100 a few days ago to give her a listen for a bit. I got two good days out of her, no protection pops.
Ran it for about 2 hours today when protection popped along with loud buzz from the L channel. Just the one pop this time around. Powerred down and removed speakers
Threw my multimeter on the terminals pretty quick to check for DC. Rmoved all inputs, volume to zero, tone defeat engaged
FIlter caps replaced ~5 years ago some service since then but not sure what has been replaced or not.
I think I'm about ready to just do this myself and stop letting shops chase white rabbits on my dime. So, I could use some sanity check. Here's where I'm at:
Next steps:
Anything else? Anything I'm missing?
- R Channel - Pretty stable reading between 1 and -1 mv
- Cycle power - quick swing to 40 mv then drops off to normal range
- L Channel - A lot more variation. DC swing from 0 to about 6.5 mv - occcasional spike as high as 180mv
- Cycle power - swings higher to about 6omv then drops off
- 1: 46
- 3: -46
- 6: -62
- 7: 62
- 2: -15.7 (-16)
- 3: -24 (-24)
- 4: -13.4 (-13)
- 5: -40 (-42)
- 8: 45.5 (42)
- 9 : 38 (35)
- 10: 26.5 (24)
- 11: 17.3 (16)
- I'm pretty sure at this point the problem is in the left channel based off the swing in DC at the terminals
- Protection circuit kind of worked as it shoud but still allowed buzz to L channel when tripped.
Next steps:
- tomorrow check secondary power supplies for ripple
- check transisters on protection circuit
- Verify alignment
- tentatively plan on replacing Q6 and Q7 on both power amp boards (known problems w them) w/ 512-KSC2690AYS
