shelly_d
Not An Audiophool
All:
I'm toying with a tube project that uses a MOSFET transistor as part of the voltage regulator for the B+. Specifically an IRF830. The data sheet on the transistor states that the mounting tab is wired to the drain. (link here: http://www.mouser.com/catalog/specsheets/91063irf.pdf).
The design constraints I have on space for this means that the transistor will be mounted vertically with the tab and attached heat sink standing straight up. My issue is that there will be about 312V
on the drain (and therefore on the tab as well) and I would like to find a way of heat sinking this so that the heat sink itself is not at that voltage.
Anyone have any ideas?
Thank you in advance.
Shelly_D
on the drain (and therefore on the tab as well) and I would like to find a way of heat sinking this so that the heat sink itself is not at that voltage.Anyone have any ideas?
Shelly_D
